how do you check coolant level when ambient temperature is 30F
2.8K views 14 replies 9 participants last post by  bluebee
#1 ·
How do you check coolant level when ambient temperature is 30F. The correct procedure demands certain ambient temp I think it is 20*c .The dipstick sticks level varies depending on temp.
I am thinking start the engine, watch ETC when it touches 20*c , consider it right temperature for checking coolant level.
#5 ·
The correct procedure demands that the engine is cool.
The level should be just below the max mark at around 20C. However, this does not mean that the temperature has to be around 20C when you check the level.
#6 ·
Well to get accurate level it required to be at the specified temperature. If it was plain water, going from 20C to 0C means about ~0,2L decrease in volume (That is with 12L coolant capacity, which is what the V8 has, I'm not sure about the I6). I don't have the thermal expansion coefficient for coolant and I'm too lazy to google it, but it should be in the same neighborhood. The bottom line is, if your a bit low on coolant when checking it at 30F don't top it up, because you'll have too much coolant.
#8 ·
I always run mine a bit low, the stick 3/4" below the top.
Less pressure build up in the system.
Been doing this for 3-4 years with no issues, just a lower pressure reading in the gauge I installed in the radiator.
#13 ·
pressure gauge in cooling system
I'm not sure I see the value in a pressure gauge on the cooling system unless one want's to monitor/detect a faulty radiator cap, aka pressure relief valve. A flowmeter might make more sense.....detect that coolant fluid flow and monitor the water pump's performance; but this is a more expensive and bit more complex an install than a pressure gauge ;)
#15 ·
JimLev posted pressure gauge readings in this thread...
- How to modify the cooling system expansion tank 2 bar cap to 1.2 bar to vent at a lower pressure (1)
See also:
- What is the proper coolant level bobber stick height (1)
And ...
- How the expansion tank works (1)
