Q1: What are the specs for E39 mounting & balancing & rotating wheels & tires?
Q2: Can tire mounting & wheel balancing possibly be done at home as a DIY?
In a vibration diagnostic thread today, RDL kindly posted the wheel runout & tire balancing spec.
I wasn't sure WHERE to specifically archive that information so others find it instantly, so I searched for E39 threads with "mount balance" or "mounting balancing" in the title, and none popped up, surprisingly.
Likewise, typing /mount F3 into the bestlinks nets only this:
- BMW wheel specs (1) & BMW & replica wheel styles (1) (2) (3) (4) & the difference between cast vs forged wheels (1) & where to find the wheel markings for proper match mounting (1) & how to choose the right size wheel spacers (1) (2) & where to go when you bend or otherwise damage your wheels (1)
So, I decided to open this thread SPECIFICALLY to define procedures & specifications for proper MOUNTING and BALANCING and Rotating tires & wheels.
Since almost nobody likely mounts and balances at home, this thread has a dual purpose (so we at least KNOW the proper procedures, even if we don't do them ourselves):
See also:
- Which of the dozen alignment specs are adjustable on the BMW E39 (1) (pdf) & cn90's front alignment DIY (1) (2) and cn90's rear wheel alignment DIY (1) & what tools measure rear camber at home (1) (2) and what tools measure front/rear toe at home (1) & what tools lock the steering wheel & brake pedal at home (1) & why does BMW recommend weights to set the normal ride height (aka nominal suspension position) prior to any alignment (1) & how to diagnose uneven tire wear on the inside edge due to camber and toe alignment issues (1) (2) & how to select a replacement tire strictly by the numbers (1) & what are the most common bimmerfest user's tire recommendations (1) & where do people buy their tyres anyway (1) & how many miles do you get for every 100 UTQG points (1) & what are the recommended tire pressures for front and rear (1) & what are the claimed benefits of nitrogen gas (1) what tire mounting tools do you need to change your own tyres at home (1) (2) (3) & where are the match mounting marks on the wheel and on the tire for precise tire mounting based on radial runout and heavy spot considerations (1) & what tools do you need to balance a wheel at home to eliminate shimmy or vibration at speed (1) & how do you properly dispose of your old worn out car tires (1) & how to measure bent wheel dimensions such as rim runout and wheel eccentricity at home (1) & where to get bent or damaged wheel rims repaired (1) (2) & what winter driving ice and snow tire chains to use (1) & what are the most recommended products for cleaning BMW BBS wheels (1) & where to buy E39 wheels online (1) & what are the main causes of vibration while highway driving (1) & vibration while highway braking (1) & how to diagnose a violent shudder while slow speed braking on bumps (1)
See also:
