E46 (1999 - 2006)
The fourth generation 3 Series (E46 chassis) was introduced in 1999 and set the standard for engineering and performance during it's years of production including being named to Car & Driver's 10 best list every one of those years! ! -- View the E46 Wiki |
This is the journey I would not take again. Major PITA. Oil separator is a "tricky sucker" like somebody commented. But I hope the pictures of every step of the way will make this diy a little easier for somebody else. I followed these 2 wonderful DIYs that contain everything you need to know:
The one by Lbert - http://www.bimmerfest.com/forums/sho...+oil+separator And the one by djmcmath - http://forum.e46fanatics.com/showthr...123&highlight= I took more pictures and included my comments making it a separate DIY. Enjoy! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
Regards, Alex *P/S Maint. and Flush DIY* *Exp. Tank DIY* *P0491 & P0492 Troubleshooting Info DIY* *CVV DIY* *ATF change GM trans. DIY* *FSU replacement DIY* *GM no reverse info * *E46 Jack Stand "Hockey Puck" Adaptor* |
Dude - Out-effing-standing job, well written and documented, another home run. Wiki-fy that beeyotch!
(and since I will be doing this some time in the next ~6 months, THANKS!
--Micah O'C CCA 193374 '88 M5, Bilstein Sports/ST Springs, staggered BBS RS, Euro conversion '04 330i ZHP, Jet Black 6spd, hot seats, LightWerkz TFX-Xenon, Bilstein PSS10 UUC Strut/SwayBarbarians, PowerFlex CAB/TAB, Performance Gearing 3.38 LSD
good job.
I propose to merge this, with the other CCV thread, as there are many good advices in that thread. Like the OP, my CCV was not leaking but it was good to get that out of the way. Also for future seekers, I would like to link this thread too: http://forum.e46fanatics.com/showthr...&highlight=ccv it has some good pics too. Last edited by AlboBMW; 12-08-2009 at 05:11 PM. |
Thanks, guys!
I think I'm done with preventive maintenance after this one for a while. This one got me ![]() I was also hoping to improve my low idle situation (my idle in drive is 625 rpm and I'd like to see it at 700rpm). Obviously cleaned ICV and throttle body, cheched DISA. All vacuum lines seem to be good. But alas...Must be torque converter. What ever...
Great DIY! Now grab a cold one you deserve it or withthe cold weather maybe soup will work best.
Very good write up!!
Question.... why didn't you take out the intake manifold??
_______________Going to Bimmerfest East AND West ![]() Youtube - Electric Fan Swap/Aux Fan Removal - Projector Retrofit - E46 Bulb Guide |
For 2 reasons: you can change the separator without removing the intake manifold. It's a pain, but do-able. And second being the difficulty level of the job of removing the manifold. It would take me like 8 more hours to do that. Here is what djmcmath from Fanatics says about the job: "Removing the intake manifold. This is a bear. You'll need to have a new gasket set and a torque wrench that's good for 11ft-lbs (you really want these torqued right), as well as a magnet-on-a-stick, some small screwdrivers, a pair of circlip pliers, and probably some other stuff. I should emphasize the difficulty here: I've rebuilt transmissions, I've pulled engines from cars with nothing but a floor jack and a socket set by the side of the freeway, I've built whole brake and suspension systems from the ground up. But even with all that experience, I dorked this process up twice in a row. If this is your daily driver and you have to drive it tomorrow, and you're not entirely confident about how this process will work, maybe pulling the manifold isn't for you tonight" So, I left it alone.
Regards, Alex *P/S Maint. and Flush DIY* *Exp. Tank DIY* *P0491 & P0492 Troubleshooting Info DIY* *CVV DIY* *ATF change GM trans. DIY* *FSU replacement DIY* *GM no reverse info * *E46 Jack Stand "Hockey Puck" Adaptor* Last edited by Starless; 12-08-2009 at 07:36 PM. |
o0o0o00o0o
Great write up! I also opted to leave the intake in place on this one. I pull wrenches for a living and found this to be a challenging job, kudos to all who take it on. Thank you Starless!
Excellent job, Alex....props to you, mang !
(R.I.P. Jever) *Please support the Wounded Warrior Project* |
Excellent write-up and pictures.
2003 325xi 5-speed & 2009 Massey 1540 HST |
You make it look so easy.
Man, thats a really good DIY!! This DIY makes it look easy but you can still see its a tough job!
Well, taking stuff apart is easy. It's the OS itself that's difficult to remove and even more difficult to install mainly due to it's extremely inconvenient to reach location deep under the intake manifold in a very tight space. On the photos you can not really see the depth but the the wrench with the torx bit at the end on one of the pictures gives you an idea. And you have to be positive that all the OS hoses are attached securely to it otherwise you'll have a leak and you'll need to start all over again which, trust me, you do not want to do. Not very difficult technically but requires lots of patience and attention. That's it.
Thanks for this writeup...I used it extensively today in doing this on my E39...
1984 318i/man./Tornadorot* 1990 525i/man./Alpinweiß* 2001 525i/man./SP/PP/Cosmosschwarz/Sandbeige* 2002 X5 3.0i/man./SP/PP/Sirius/BT/Titansilber/Sandbeige* 2006 330i/man./SP/PP/CWP/Sirius/Blackline/Rear Fogs/Arktis/Grau* 2001 525i/step./SP/PP/CP/CWP/Xenons/Rear Shade/OEM Sirius/OEM BT/OEM AUX/M5 Rear Sway/Bilstein HDs/Beisan Vanos/Rear Fogs/Schiefergrün/Sandbeige* 2012 VW Golf R/Rising Blue *retired |
great job.
looks way too complicated for my patience lol
mujjuman |
Fantastic DIY! I'll be using this one for sure when it's time.
The word "there" can appear as a pronoun, as in “over there". "Their" is a possessive pronoun. In a phrase like “Susan and Bill's car,” it could be used to to make a new phrase: “their car.” ”They're” is a contraction of “they are.” “They are” should always be able to replace “they're.” Extra credit: It's "I'm looking for an M3" not "I'm looking for a M3". |
Very Helpful! I used this last night, it makes it so much easier to have a pictorial guide.
Chris 2008 528i - Deep Green Metallic |
I assume this process is similar on a 1995 525i E34? Can anyone confirm? I did the vanos rebuild and broke the rubber hose that goes from vanos to cvv. I could not retrieve the distal end to attempt a reconnect. At 192K the cvv is long overdue anyway.
Great write up!
While I can't confirm that they are similar, I did my CCV for the same reason, those plastic tubes are very brittle later after a few miles... Because it broke I learned all about the CCV and in the process found that the tube that attaches to the dipstick was completely clogged in the metal portion of the dipstick.
Great job on the DIY Alex...I just did this yesterday and you're DIY was key.
I would like to point out one observation though. On re-installation, I found it easier to install hose #2 first while in place in the car as this hose must be rotated. This allowed me to connect all hoses within 10 minutes! Let me point out that I have a MY 2000 323i with an M52 so install may be a little different. Again, thanks for the DIY, Great Job! Last edited by MMME30W; 08-10-2010 at 05:58 PM. Reason: Snip duplicate post quote - readability improvement |
What failure caused you to do this job?
![]() Dsenier - 01' 325i |
#25
I'm grateful for all the great pics. I'm fortunate that I have a second bimmer to drive, so when I get frustrated I can just walk away and return the next day, fresh. I broke the vanos down into four days, and it went quite well. But with the vanos there wasn't any really tight spots. Everything is easily accessable. From what I've read this cvv is going to be a bear.
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
