Cute little trick to diagnose blocked CCV system...
1 reading
472K views 91 replies 39 participants last post by  crazy4trains
#1 ·
I just came across this interesting little trick for diagnosing blocked CCV in the Volvo forum:
With the oil cap sealed, engine on, stick a balloon over the dipstick tube and see if it inflates. If it inflates you need to service the PCV system.
...Lee
I think he meant with the dipstick removed, so the balloon goes over the dipstick housing.
No balloon, no problem, get an old dish washing glove, cut a "finger" off and tie it with rubber band.
http://www.matthewsvolvosite.com/forums/viewtopic.php?f=1&t=28322
#3 · (Edited)
Any pressure will become evident as soon as the engine is turned on--what they are pointing to, is that
the pressure to just partially inflate the balloon is evidence the pvc system needs work.
I would guess that when trying this procedure on our cars--if the ballon trys to be sucked into the
dipstick hole just a little that all is OK--if it's being sucked in at a high rate though the ccv could be going bad.
#5 ·
..if the ballon trys to be sucked into the
Poolman,
Dipstick housing represents crankcase prssure, so it is almost always high from blow-by combustion. The dipstick can never suck in.
Vacuum exist in the Intake Manifold only.
#4 ·
On the VANOS repair site (Rajaie) posted this trick
"The crankcase vent valve and 4 associate hoses fail and cause a vacuum leak. The valve gets stuck open and the hoses crack. These last 70-120k miles and usually fail 80-90k miles. Here are a couple diagnoses.
At warm idle, place a small plastic freezer storage bag on its side over the oil fill hole. If the bag sits on top or gets slightly sucked in, ~1***8221;, the valve is good. If the bag gets significantly sucked in the hole the valve is stuck open and bad.
With the engine off and cold, carefully remove the hose at the valve cover front corner. Blow hard into the hole. You should hear oil bubbling in the oil pan. If you don***8217;t hear the bubbling the top or bottom hose is likely cracked. The bottom hose often breaks just below the valve connection. There can also be cracks in the other two hoses."
#11 ·
At warm idle, place a small plastic freezer storage bag on its side over the oil fill hole. If the bag sits on top or gets slightly sucked in, ~1", the valve is good. If the bag gets significantly sucked in the hole the valve is stuck open and bad.
With the engine off and cold, carefully remove the hose at the valve cover front corner. Blow hard into the hole. You should hear oil bubbling in the oil pan. If you don't hear the bubbling the top or bottom hose is likely cracked. The bottom hose often breaks just below the valve connection. There can also be cracks in the other two hoses."
This bag trick is messy on the 540i because the oil fill location is on top of the timing chain, which when the engine is running will whip oil through the oil fill hole. I think the ballon trick would be best for the V8's.
#6 ·
Not sure who is right here but Gtxragtop (Dave) did a test on my dipstick tube to determine CCV function by measuring the amount of vacuum pulled (I can't remember but I think the proper amount is 3"-6" of water). Not sure where this test came from (TIS?). No/low vacuum meant a CCV problem. My understanding is this test measures the amount of vacuum in the crankcase. But I am not sure how the pressure in the sump translates to the pressure in the crankcase. According to this test, the sump should have negative pressure and pull on the balloon, if the CCV is functioning properly. If it inflates the balloon, there is definitely a problem as that would indicate positive pressure in the sump. In addition, positive pressure in the sump should also blow the dipstick out of the hole. In theory the CCV is supposed to keep the crankcase from a positive pressure condition and that a failed CCV will create a positive pressure situation by keeping the crankcase from venting gases. If I sound confused, it is because I am. :dunno: All I know is that I replaced the damn thing and I have stopped burning oil.
#7 ·
In a nutshell, the crankcase always produces pressure from blow-by. The CCV is simply a "middleman" controlled by Intake Manifold Vacuum.
This way the positive pressure from the crankcase is removed by the CCV which separates oil and vapor:
- Oil goes back down the crankcase
- Vapor goes back into the Intake manifold.
This is why the CCV is also called "Oil Separator" in the Volvo language.
#9 ·
Got most of that. Someone correct me if I am wrong. I refer to the real.oem diagram for the CCV. The oil and vapor from the cylinder head (positive pressure) goes into the CCV through the vent pipe (2). The CCV "separates" the liquid from the vapor and returns the vapor portion back into the intake manifold (negative pressure) using the connecting line (3) and the return pipe (7). The liquid oil condensate flows back into the sump via the vent hose (4).
If the previous is correct, is the sump at negative pressure, ambient or positive pressure? The dipstick vacuum pressure test suggests it is at negative pressure.
I ask because my previous e39 (which Gtxragtop tested) tested OK for negative pressure even though the car demonstrated some of the classic symptoms of CCV failure (oil consumption, burning oil, etc.). My current e39 appeared to burn oil (occasional black exhaust smoke in cold weather) but was never tested. I changed the CCV and that has gone away. It would be great to have a reliable test to verify proper CCV function as it is a PITA to change out. At this point, I am not so sure the dipstick vacuum test is that reliable of an indicator.
#10 ·
Fudman,
The best way to look at this is:
1. "A" is the crank case pressure. It is the same whether you measure it at the Top Valve Cover Outlet or the Dipstick because the Top part of the Engine Cam Lobes area connect to the sump via some air channels (this is how crankcase air goes from the sump upward into the cam lobes area).
2. "B" is the Intake Manifold Vacuum.
The following numbers are arbitrary just to illustrate the concept.
Sea level air pressure is 760 mm Hg or 14.7 psi. But let's set this as zero as a point of reference purpose.
And let's say the CCV is designed such that when there is a differential of 3, it opens the spring allowing vapor to return to the I.M.
Scenario A: car warm and idling at 700 rpm:
- Atmospheric air "zero"
- Intake Manifold vacuum = "- 1"
- Crankcase Pressure: goes slowly from "1" to "3" (from blow-by)
At "-1" and "1", the difference is only 2, so the CCV is closed, but at -1 and 3, the difference is 4 so the CCV is open allowing vapor to return to the I.M. At the same time, liquid (oil) is allowed to flow back down the crankcase drop by drop (basically dripping, not a full flow).
Scenario B: you are driving at 3000 rpm:
- Intake Manifold vacuum = "- 3"
- Crankcase Pressure: goes slowly from "3" to "5" (from blow-by)
In this case the CCV is always open because the min difference is still 6.
Maybe one of us can get a birthday balloon and play with it this weekend and report back (assuming your CCV is fine)?
#14 · (Edited)
The best way to look at this is ...
Hi Cam,
Looking at this diagram (to figure out how the CCV works), did I draw the directions of the pressure (orange) and vacuum (yellow) in the M54 engine correctly?
Notice you do not show the direction of the thin line called "vacuum hose", so I 'guessed' at which direction the flow is going.
Likewise, the Realoem diagram for my M54 engine seems to have the "return pipe" reversed, so, that adds a bit of confusion.
Can someone correct this diagram so that we have the correct directions for the M54 CCV?
#12 ·
CN90--don't know about you M52--but my M54 has always had vacuum at the dipstick as well as the valve cover oil cap--on the later engines there is a vacuum directed into the crankcase via the valvecover gasket
the oil dipstick tube has two different channels in it to allow oil to drainback and the dipstick itself.
One of the big problems that must be watched out for when doing the ccv valve work on the M54 engine
is to make sure the dipstick tube 0 ring is seated properly when doing the reinstall and ensureing there isn't a vac leak there. Vacuum is introduced into the crankcase from the distribution unit--then to the ccv and from there to the valve cover.
#13 ·
The crankcase, valve cover, dipstick tube are all connected by wide open space. Remember, the oil on the camshaft has to drain back down to the sump. According to the TIS, the vacuum should be between 3-6" of WATER no Hg (mercury) which is the measurement used on a typical vacuum gauge. 3-6" of H2O is not very much. The goal of the CCV as others have stated is to maintain a slight vacuum under all conditions.
#17 · (Edited)
Your flow directions are correct except for the vacuum hose. The RealOEM parts diagram is INCORRECT. There is NO vacuum hose.
Now that's interesting.
I realize YOU have the same M54 that I do, and that you already replaced your CCV, so you should know:
- DIY: CCV Replacement on an M54 & Replacement of the CCV on M54, both by Fudman
However, from reading all the DIYs, I do know 'some' CCV's have a black orange-striped vacuum hose:
- DIY: change of the CCV / Pressure regulating valve / oil separator, 99 528i, by aioros
So, the question is, if realoem is wrong, how do we know, ahead of time, WHICH ccv's have the vacuum hose and which don't?
#19 · (Edited)
the M54 3.0 does not have this vacuum hose. I believe rdl's experience mirrors mine.
I have a M54B25 but I'll wager it's similar (since it's an M54).
Certainly Aioros' 99 528i has the (orange-striped) vacuum line connected to the CCV.
In 'that' case, which direction is the vacuum?
  • Is the vacuum in that line a 'result' of the huge (in comparison) lines connected directly to the intake manifold?
    • In which case, the arrows should point INTO the CCV
  • Or is the vacuum in that line a 'signal' to the CCV from some other vacuum source
    • In which case, the arrows should point AWAY from the CCV
#20 · (Edited)
Based on Fudman's comments, I searched for RDL's comments and found where he also confirmed his 530i also does not have the orange-striped vacuum line that Aioros has on his 99 528i.
- CCV replacement tips
BTW, my M54 does not have pt# 6 "vacuum hose" although RealOEM indicates it is supposed to be present
Here is the realoem diagram for a 11/2001 production month 530i showing the vacuum hose that isn't there.
Of course, that realoem diagram also shows a #8 which isn't described; and it shows the #7 return pipe reversed ... so, it's not infallible!
#22 ·
if I put a rubber inflatable device over the dipstick tube, am I going to get it to expand or contract?
Details here:
- How to test the crankcase ventilation (aka CCV, CVV, PCV, CPV, & OSV) pressure regulating valve system (1)
And why are there incorrect, if they are, diagrams here?
Ummm... because the diagrams are (slightly) incorrect. But, unless you want us to draw new ones, we're stuck with the incorrect ones.
And it seems different years had different hoses, correct?
They're mostly the same. AFAIK, the key difference is that the CCV itself looks different depending on the model year, and, the orange-and-black vacuum hose is not on the newer models.
What is the simple test(s)?
For my M54, I simply placed a plastic bag over the oil filler hole:
- Pictorial DIY for an M54 spark plug replacement on a 2002 BMW 525i E39 with 95K miles
#34 ·
I looked at the diaphragm again. I can confirm that the diaphragm does indeed close off the vacuum to the intake manifold and that the crankcase vacuum is not closed off by the diaphragm when the the diaphragm is closed. I'll post a few pictures later today.
#36 ·
I think we are all on the same page here. The diaphagm isolates the manifold vacuum (approx 260 inches of water) from the crankcase once the crankcase vacuum reaches 4-6 inches of water. The diaphagm modulates opening and closing the port to the intake manifold which regulates the crankcase vacuum to 4-6 inches of water.
Gary
#37 ·
Thanks.
Here are two photos.
The first shows the opened vacuum regulator. This shows the diaphragm, the spring and the case. Note that the diaphragm seals off the hose going to the intake manifold, but does not seal off the central tube that allows gases to flow from the oil separator. The central tube and oil separator are at crankcase pressure.
The Second photo shows the oil separator of the CCV. I passed a red wire around the spiral to show the path of the gasses and show that it is a spiral. Note I drew the yellow line to show the inner edge of the spiral web on the oil separator. The oil and gasses enter from the left and travel along the spiral path until it reaches the central tube.
#50 ·
Sorry for the late reply - I just looked at this thread again.
Indeed I posted the same photo twice. I've posted the second photo below. It shows a section through the M54 oil separator part of the CCV.
I doubt this adds anything to the current discussion, but I wanted to post it for completeness.
#39 · (Edited)
I'm here searching for a definitive way to test whether the steel CCV vent tube (integral with the oil dipstick guide tube) is clogged.
Mine was totally clogged recently.
I cleaned it out - but - how would I know when it becomes clogged again?
All the diagnostics I found were for testing the CCV itself, not for testing the steel vent tube.
BTW: I live in a warm clime ... where it (almost) never freezes ... and hardly ever rains ... so ... that tells me (almost) EVERYONE needs to check to see if their dipstick guide tube is clogged (unless they have a retrofit).
Q: Without removing it, what test, if any, will tell us the dipstick guide tube is clogged?
#41 · (Edited)
I have an M54 so I'm not really familiar with your engine. I have though seen the pictures and diagrams of the air hose off the CCV running to the fuel pressure regulator.
When I first saw those pictures a couple of years ago, I was baffled at the design intent. I finally realized that "operated with crankcase vacuum" is technically accurate. But assuming the CCV is working properly it is really so close to atmospheric pressure that it makes no practical difference. The CCV regulates crankcase vacuum to less than 15 millibar, or EDIT 1.5% (not 0.15% in original post) different from atmospheric pressure.
I think the purpose of taking a reference pressure this way is to provide clean, filtered source of atmospheric pressure to the fuel pressure regulator without any chance of engine bay dirt, grit and grime fouling the sensitive parts of the small fuel pressure regulator. By comparision, the CCV is about 3 inches in diameter & much less sensitive to dirt. An awkward, klugey way to achieve the result in my opinion.
For the M54, BMW changed the design to take atmospheric reference pressure from the F fitting in the boot between the MAF and inlet manifold. That supply is kept clean by the engine air cleaner.
#53 ·
I never thought of it as a reference to atmospheric pressure. I've assumed that it was necessary too let the volume behind the diaphragm vary without restriction.
As I recall, in one type of FPR the return flow is blocked under low vacuum, such as acceleration. Another type of FPR actually increases return flow under high vacuum situations like idling. I suppose one could design a FPR to do both, but I've assumed that the FPR on the e39s are the second type that lower fuel rail pressure during high vacuum.
If I understand what you've written, you think that the FPRs on the e39s don't really use a vacuum source to move the diaphragm, only to vent area behind the diaphragm. Certainly the M54 FPR will not see a strong vacuum since it's connected upstream of the throttle. Assuming that the CCV is operating at crankcase vacuum, it would be insignificant for the M52, too.
#54 ·
... stuff deleted ...
A simple FPR will do both automatically, it wouldn't need two different types or a special, complex design. In both the cases you describe injector pressure changes in the same direction as the change in reference (manifold) pressure. This is normal response for a pressure regulator. You can work through the steps by considering vacuum to be -ve pressure and that blocking return increases injector pressure, increasing return flow reduces injector pressure.
I should clarify that vacuum doesn't move the diaphragm and the hose isn't simply a vent. Rather the balance of force from reference pressure on one side, force from fuel pressure on the other side, plus spring force determines the output pressure. The purpose of the air hose to FPR is to provide the reference pressure that the engine designer planned.
TIS describes that the M52 does change fuel pressure under different engine load conditions (high load / acceleration = low manifold vacuum, low load / idle = high vacuum) and apparently uses varying vacuum to the FPR to do so. However as I mentioned in the earlier post, I just can't work out how the tap off the CCV provides that changing vacuum to the FPR. :(
TIS does not say anything about the M54 varying fuel pressure with load.
