locations and part numbers
Old Post, new post - does not matter and in fact good posts, search and review before posting are the key.
SO, I have the same situation as you, and have ran diagnostics with the computer.
Codes P0491 and 2 - hoping it is not carbon clogging the heads...
1. I hear the pump on start up for like the 90 seconds as stating
1a. I also hear a bunch of air noise from under the upper intake manifold in front of the motor
2. Connect diagnostics computer, go into diagnostics, turn pump on - turns on fine, I hear the air noise.
3. Next step is to feel for air out the exhaust = fail
The Y in front of the motor seems fine, but the lines around them seem to be good but maybe hard like you say. SO a couple questions (and I'll do more searching, but this is right on topic):
Q1: "Next I checked the vacuum line connecting to the secondary air exhaust valve." - Where is this?
Q2: "They were hard and brittle and when it tried to pull it off the valve it broke apart." - Was this under the intake manifold? Any pix?
Q3: "So I replaced all the old and hard vacuum lines all the way back to the engine intake. Reset the codes and it hasn't come back. Turned out to be a cheap fix."
Can you post the part numbers and I can then use real OEM to see where they are? thanks a mil.
