Hi All,
So i discovered that i've got a Bosch 5.7 abs module on my car (after buying soldering iron and magnifying glass). Turns out it looks different from Bosch 5.3 and harder (if not impossible) to DIY repair.
Like most others, recession is bitting so im not eager to buy a new/remanufactured abs module just yet. I had a brainwave, i usually disconnect the faulty abs module completely as it messes up my braking (constant abs pulsing everytime). Well i know the speedometer and mpg guage are seperate from the abs pump working but reliant on just the abs controller calculations. I want to disable/ignore ABS feature without loosing fuel sender accuracy, speedo and mpg guage.
in the attached picture, those cylindrical things contact the abs pump when fitted to the rest of the system however i noticed they are held by flimsy springy rails, is it safe to remove them or perhaps insulate the contacts from the abs pump?
Seems like a cheaper fix in that the module is screwed anyway. plus i can live without abs. Just worried ive overlooked some other implications.
