I'm trying to identify all my relays and fuses but ran into a technical difficulty preventing me from removing the ebox cover under the passenger air filter on my 2002 525i...
May I ask these three questions:
Q1: How do you best remove the ebox cover itself (see pictures below)?
Q2: What are the numbers (& purpose) of the fuses in that ebox?
Q3: What are the purposes of the relays in that ebox?
Here, for the record, is how I tried to remove the ebox cover:
First, I removed the passenger side cabin air filter housing ...
Then, with a 5mm hex wrench, I removed the 4 cover bolts:
I looked for a fifth 5mm hex cover bolt but did not see any more than four bolts holding the cover in place:
But, I couldn't figure out how to actually REMOVE the cover!
I could barely see the set of fuses behind the myriad wires in the back of this ebox:
And, I could see only two relays in that ebox.
