Picture & amperage & description of every single fuse & relay in the BMW E39
EDIT: Added excellent fuse descriptions from Steve530 from post #4 on 3/3/2012.
EDIT: Added cross-references to specific fuse-related posts by QSilver7, RDL, cn90, & JimLev 3/13/2013.
EDIT: Added a nice closeup of EF1 to EF5 by tobesscooby 4/6/2013.
EDIT: Added better descriptions for F107 to F114 by rdl on 4/8/2013 (and added fuse amperages for the unknown fuses, again, as per rdl).
Let's see if we can list, describe, locate, and show a photo of every fuse and relay in the BMW E39, so that we all benefit.
Below, (from this quest to locate a parasite), is as far as I've been able to get detailing every single fuse in my 2002 525i.
(Note that F1 to F5 exist in two different locations, just to confuse you, so I'll refer to the ebox ones as EF1 to EF5, and the glovebox ones as F1-F5).
There are SIX fuse box locations in my 2002 BMW 525i E39 (here is a 1997 540i fuse location chart):
EF1 = 30A, MAF, Cam sensor #1, DME, T-Stat, Evap emission valve (some say it's 30A - DME, Injectors, SMG Hydraulic unit)
EF2 = 30A, Fuel injectors, Both Vanos solenoids, Cam sensor #2, SAS pump electrical valve (some say it's 30A - DME, Idle control valve, Fuel tank ventilation valve, Fuel pump)
EF3 = 20A, Cam sensors, MAF, Crank Sensor, Heated O2 sensors (some say it's 30A, others say 25A - E-box fan, Transmission RPM sensor, CPS, MAF sensor, Fuel pump relay, SAP relay, A/C Compressor relay, Fuel tank leakage diagnostic module, SMG selector lever)
EF4 = 30A, DME (some say it's 30A - Oxygen sensors and oxygen sensor heater circuits)
EF5 = 30A, Unloader relay, power to coils (some say it's 30A - Fuel injector relay)
IMPORTANT: The five EF fuses are NOT labeled! Only the values are labeled, but they are symmetric!
It turns out (later in this thread) that EF1 is the left-most fuse (left being defined by being able to read the MOTOR-SICHERUNGEN (aka "engine security measures") printing on the fuse cover itself).
Note: There is a black or white cap enshrouding the five ebox fuses EF1 to EF5, which needs to be removed as explained by RDL in this thread.
Photo below courtesy of JimLev shows the white cap still in place enshrouding the five ebox fuses:
IN THE ROOF PANEL OF THE GLOVEBOX:
F1 = 30A, Windscreen wiper
F2 = 30A, Headlight cleaning system, Windscreen washer system
F3 = 15A, Horn
F4 = 20A, Passenger comp/trunk lighting, Windscreen washer system
F5 = 20A, Sliding tilt/roof
F6 = 30A, Outside mirror adjustment, Central locking system, Window lift (rdl says fuse F6 supplies the passenger door module power only for both windows and locking motor, no other door; F6 enters the door via connector X256 pin 26.)
F7 = 30A, Cigarette lighter
F8 = 25A, ABS/ASC Control Module (Note: F8 was empty in my 2002 525i)
F9 = 15A, Air conditioner, Heated washer jets [JimLev says it handles the heated washer jets and the Check Control Module panel]
F10 = 30A, Passenger seat adjustment
F11 = 7.5A, Servotronic
F12 = 5A, Immobilizer
F13 = 30A, Driver seat adjustment, Steering column adjustment [JimLev says F13 goes to all of the motors in the drivers seat and the two steering column adjuster motors in a left hand drive gas engine E39 built after 9/'99] [cn90 shows an F13 trick here][cn90 says to prevent seat twist, pull this fuse]
F14 = 5A, Engine control
F15 = 7.5A, Diagnosis plug, Engine control (JimLev adds: Oil level sensor, Data connector under the hood next to the ABS module (no data conn after ~6/2000), Alternator, Temp switch in DME box for cooling fan in bottom of DME box, Range switch for automatic tranny)
F16 = 5A, Light module
F17 = 10A, ABS, Automatic stability control
F18 = 5A, Instrument cluster
F19 = 5A, (empty) Electronic damper control [QSilver7 says F19 is in-between the ignition switch and an unloader relay terminal 15]
F20 = 7.5A, Air conditioner, Heated rear window, Heater, Tyre pressure control system [JimLev says F20 and F105 power relay K201, which itself gets power from F75]
F21 = 5A, Anti-glare inside mirror, Driver seat adjustment, Garage door opener [JimLev says F21 also powers the current cutoff relay, garage door opener, rear view mirror, park distance control module, and the cig lighter relay]
F22 = 25A, Fuel pump
F23 = 7.5A, (empty in my 2002 525i) Heater, Rear centre arm rest
F24 = 5A, Instrument cluster, Shifting gate illumination, Tyre pressure control system
F25 = 7.5A, Multi-information display, Radio
F26 = 5A, Wiper Relay I & Wiper Relay II (Note: F26 was empty in my 2002 525i)
F27 = 30A, Central locking system, Window lift
F28 = 15A, (empty in my 2002 525i) Transmission control, diesel
F29 = 30A, Central locking system, Outside mirror adjustment, Window lift
F30 = 25A, ABS
F31 = 10A, ABS, Automatic stability control, Fuel pump
F32 = 25A, Active seat, Electric seat heating, Roller sun blind
F33 = Open (empty in my 2002 525i)
F34 = 10A, Heated steering wheel (empty)
F35 = 5A,(empty in my 2002 525i) Rear A/C blower
F36 = Open (empty in my 2002 525i)
F37 = 5A, Immobilizer
F38 = 5A, Horn, Shifting gate illumination
F39 = 7.5A, Charging socket, Courtesy mirror illumination [professorman says it's also for the glovebox flashlight charger]
F40 = 5A, Airbag, Instrument cluster
F41 = 5A, Brake light, Light module
F42 = 5A, Airbag
F43 = 5A, (Telephone), (On-board monitor), Radio, (Rear Washer) (Rear washer pump)
F44 = 5A, Multi-function steering wheel, MID, Radio, (Telephone)
F45 = 7.5A, Roller sun blind
IN TRUNK BATTERY COMPARTMENT:
F46 = 15A, Blower relay/Parked Car ventilation/Receiever, parked car ventilation (Note: F46 was empty in my 2002 525i)
F47 = 20A,(empty in my 2002 525i) Additional heater, independent heater
F48 = 5A, Anti-theft alarm system
F49 = 30A, (empty in my 2002 525i) Air suspension
F50 = 7.5A, (empty in my 2002 525i) Air suspension
F51 = 30A, (empty in my 2002 525i) Rear cigarette lighter
F52 = 30A, (empty in my 2002 525i) Cigarette lighter (AUS)
F53 = 7.5A, Central locking system [fuel door solenoid issue, which disables the central locking system] [JimLev adds Rear lid motor relay K70, Central locking & fuel door relay K121, Window motor relay K90, Diversity amp or antenna amp]
F54 = 25A, (empty) M5 Fuel pump
F55 = 20A, (empty) Rear washer, Rear washer pump
F56 = 30A, (On-board monitor), (CD changer), Radio, (Navigation system) [Black540eye adds On-board Monitor, Radio, Video Module, CD Changer, Amplifier, GPS Control Module, GPS Receiver]
F57 = 10A, (Telephone)
F58 = 10A, (On-board monitor), (Telephone), Radio, (Navigation system)
F59 = 20A, (empty) Trailer socket
F60 = 50A, (empty) Elecronic damper control
F61 = 5A,Park distance control module/ Seat heater switch, left rear/ Seat heater switch. right rear (empty in my 2002 525i)
F62 = Open (empty in my 2002 525i)
F63 = 7.5A, Radio relay/ Loud alarm relay/ Transparency relay/ Alarm control unit (empty in my 2002 525i)
F64 = 30A, On-board monitor/ Radio CD changer/ Amplifier/ GPS receiver (empty in my 2002 525i)
F65 = 10A, Transceiver (empty in my 2002 525i)
F66 = 40A, heated rear window
THESE DO NOT EXIST:
F67 = (does not exist in the E39)
F68 = (does not exist in the E39)
F69 = (does not exist in the E39)
F70 = (does not exist in the E39)
F71 = (does not exist in the E39)
F72 = (does not exist in the E39)
F73 = (does not exist in the E39)
F74 = (does not exist in the E39)
BEHIND GLOVEBOX (look from underneath):
F75 = 50A, Auxiliary fan (red) [QSilver7 says the aux fan is the electric fan in front of the radiator which also goes on when the AC is initiated.][bluebee removal hint]
F76 = 40A, Heater blower (yellow) [cn90 says it should have 12V when HVAC is turned on][QSilver7 says the heater blower controls the air velocity for the cabin/interior HVAC system.]
Neither of these huge fuses is easy to remove or put back (due to the cramped location), but luckily the yellow one is the one aft, which is easier than the red to remove.
THESE DO NOT EXIST:
F77 = (does not exist in the E39)
F78 = (does not exist in the E39)
F79 = (does not exist in the E39)
F80 = (does not exist in the E39)
F81 = (does not exist in the E39)
F82 = (does not exist in the E39)
F83 = (does not exist in the E39)
F84 = (does not exist in the E39)
F85 = (does not exist in the E39)
F86 = (does not exist in the E39)
F87 = (does not exist in the E39)
F88 = (does not exist in the E39)
F89 = (does not exist in the E39)
F90 = (does not exist in the E39)
F91 = (does not exist in the E39)
F92 = (does not exist in the E39)
F93 = (does not exist in the E39)
F94 = (does not exist in the E39)
F95 = (does not exist in the E39)
F96 = (does not exist in the E39)
F97 = (does not exist in the E39)
F98 = (does not exist in the E39)
F99 = (does not exist in the E39)
ABOVE BATTERY POSITIVE TERMINAL:
F100 = 200A, Fuse panel 4, F107-F114
F101 = 80A, Power supply for fuses F46-F50 and F66
F102 = 80A, Power supply for fuses F51-F55 [wiring diagram here]
F103 = 50A, Open
F104 = 50A, Unloader relay terminal 15
F105 = 100A [JimLev says F20 and F105 power relay K201, which itself gets power from F75] (rdl says his F105 is 100A)
F106 = 100A, F75, Engine cooling fan relay stage 3
UNDER PASSENGER SEAT: (see more details in this thread & this thread)
F107 = 50A, SAS airpump Special Fuse: BMW PN 6113836590 (rdl says it's the secondary air relay fuse)
F108 = 50A, [QSilver7 says this is for the ABS/DSC control unit] (rdl says it's the "motor relay") (rdl clarifies that the F108 "motor relay" fuse supplies ASC or DSC) (rdl says his F108 is 50A)
F109 = 80A, [QSilver7 says this is for the DME (motor electronics)] (rdl says it fuses the Ebox EF1 and the DME relay in the ebox) (rdl says his F109 is 80A)
F110 = 80A, Power supply F1-F12 and F22-F26 (rdl says this fuses about 17 fuses, up to F45) found in the glovebox)
F111 = 50A, Data link connector/ Ignition switch (rdl confirms this is the ignition switch fuse)
F112 = 80A, Light control module (rdl confirms this is the LCM fuse)
F113 = 80A, Power supply F13 and F27-F30/ Light Module (rdl says it fuses the LCM and several fuses in glovebox plus in some cars a "closed-circuit current cutout relay" which then feeds a fuse in glovebox)
F114 = 50A, Data link connector/ Ignition switch (rdl confirms this is for the ignition switch and diagnostic plug)
In addition, there is a 10A fuse on the back of the Radio/MID as per cn90 over here:
- EF1 to EF5 <= at the back of the ebox under the passenger side cabin air filter housing (5 fuse spots)
- F1 to F45 <= in the glove compartment top panel (45 fuse spots)
- F46 to F66 <= directly above the battery (21 fuse spots)
- F67 to F74 <= don't exist
- F75 to F76 <= behind the glove compartment (2 fuse spots)
- F77 to F99 <= don't exist
- F100 to F106 <= above the battery positive terminal (7 fuse spots)
- F107 to F114 <= under passenger side front seat carpet (8 fuse spots
F3 = 15A, Horn
F30 = 25A, ABS
F42 = 5A, Airbag
THESE DO NOT EXIST:
THESE DO NOT EXIST:
F103 = 50A, Open
