A set of coolant posts showed up recently with the usual questions about it. I have spent much time looking into this topic and would like to share what i've gleaned from the web, from others here on the fest, and from my own trials with my ride. I believe i understand this topic in its near entirety. What i have discovered will prove controversial for some.
Before that, let me state the baseline for clarity. Coolant chemicals were created to both lower the melting point and raise the boiling point of water. This helps coolant stay liquid in the winter and handle the normal operating temperatures of your engine without boiling over. (A pressurised cooling system also helps to raise the coolant's boiling point, for the same reason).
So now, onto the facts :
1. All coolants are compatible with each other. They can be mixed with each other with no problems.
2. Coolants have different colours due to different colouring DYES added to the coolant, not different active chemicals.
3. All coolants use ethyl glycol as their base chemical. The more of this chemical you have in your system, the lower your melting point and higher the boiling point of the water-coolant mix.
4. 100% ethyl glycol is not required - too expensive, and is a case of over-engineering for the car's heating systems as the car is designed to run at around 100 degrees celsius or around there.
5. Manufacturers add various coloured and aromatic dyes to their coolant to accomplish three objectives :
a. Brand identity for marketing purposes. This can be used to more easily convince people that "my coolant is better than his coolant" etc.
b. Visibility. Ethyl glycol is colourless. Adding colour enables you to see the coolant more easily through the expansion tank, and spot any leaks in your cooling system that much more easily as compared to a colourless leak. People are also less likely to mistake it for water and drink it as well.
c. The ability to smell the coolant. Ethyl glycol is odourless. Aromatic chemicals are added to enable you to smell the coolant. The main reason they do this is so that any coolant leaks in the engine bay will cause the strong coolant smell to immediately invade your cabin (air reaching the cabin does get sucked from your engine bay before going through your microfilter)...and the driver is instantly alerted to a possible problem before the leak gets so bad that the engine begins to overheat.
[ This simple fact helped me arrest two situations recently which involved ruptured coolant hoses. I have become a firm believer ever since. ]
6. Manufacturers also add anti-electrolytes to their coolant. This will suppress rust formation. They are also known as rust or corrosion inhibitors. I'm not exactly sure which are the specific chemicals involved but they are definitely NOT rocket science either so all the manufacturers use essentially the same chemicals.
7. Newer engines use an all-aluminium alloy cylinder head and block. This stuff does not rust at all. I was told that it has other problems, so the corrosion inhibitors in regular coolant does help too, but I can't confirm this. Stopped my research - pointless as my car has an iron block.
8. There's a company called Evans that sells a zero pressure cooling fluid called NPG+ (this is a brand name). Its basically 100% propanol which (if i'm not wrong) is an isomer of ethyl glycol, and is thus non-aqueous i.e. does not involve any water. This stuff is expensive and after consultation with bentley's ghost, i decided that it was not worth the continuous investments involved compared to other things like high-flow water pumps, low temp thermostats, silicone or steel lined coolant hoses, new expansion tank seals, new coolant piping etc. There's no harm in using it at all, many have done so with great results, but I'm not totally convinced that the claimed benefits of eliminating in-situ micro vaporisation in the cylinder head is really significant. Plus, cheap coolant is well cheap, and enables you to affordably flush your engine twice a year, which is something that i find really fun to do for some inexplicable reason.
9. There are mechanics out there who have gone on record to say that only BMW coolant is safe for our cars. Of course, if you're a mechanic, and you're going on public record, and you're making a statement that covers the whole world, and perhaps if you wish to be nice to your sponsors, you're not likely to make any statements which involve ANY risk whatsoever, will you? And you can't be taking any risk when you say that bmw coolant is best for bmw, toyota antifreeze is best for toyota, etc etc. Even if anything goes wrong, the billion-dollar manufacturers will race in to back you up. Plus most mechanics are not educated or do not have a scientific bent in their approach to things, so they rarely take risks about chemicals and the physics of the engine etc.
10. The auto industry, and basically, capitalist industry itself consistently twisting the truth, misleading and not-infrequently lying to the public in order to fortify their own profits, is nothing new is it? Can you blame them when there are legions of hypnotised gullible people around? So caveat emptor, wide reading and good relationships with like-minded enthusiasts helps to educate one against nonsense, which will ultimately have a direct and measurably beneficial effect on one's bank account and peace of mind. If you don't take that approach, not only will you be a victim of the loads of bull**** out there, you'll become its perpetrator as well when you spread your misinformation to others.
11. My advice to you? Chuck the bmw coolant immediately. Add 2 cans of concentrated cheap luminescent yellow/green coloured strongly sweet smelling coolant into your radiator, and keep one can in your trunk at all times. Please see the following picture for a sample, in fact please see three pictures, of the coolant I use, that's made in San Diego :
If possible, get a refund or an exchange for your spare bottles of bmw coolant. It costs nearly 4 times more, is not as bright as the cheap stuff, and does not have a strong smell at all. You need these two elements for reasons mentioned above. There are no particularly brilliant proprietary corrosion inhibitors in bmw's coolant worth paying a premium for as well.
Its your money and your car. If you want to take the risk of using a very mildly aromatic coolant like what bmw uses, that's up to you. Yes, you read right, to me, using bmw coolant is RISKY when compared to cheaper, strong smelling stuff particularly when it comes to older cars, engines, hoses, radiators, etc. Of course, paying more for coolant does ultimately help to stimulate the economy, create more jobs and end world hunger and enable each child to get 1 free pass to Disneyland every year, so I suppose it is worth doing. lol
Everything I've written above can be verified after reading sufficient articles on the net. So please, do take my advice, I am using it !
