Ok, I posted this in post for m62 engine but it was probably not right, so why wouldn't we create something for M52? Hopefully it will help somebody...
OK, my few cents on this...
Currently I'm changing all vacuum hoses I can find in my 1997 528i. For now I found 2 diagrams with them:
1. Secondary air pump vacuum control
Here, I changed number 7 and 10 already with 3.5mm vacume hose. Wait till weekend to change 13 and 15 as I need to remove more stuff to get to them.
2. Fuel tank breath valve.
Here I changed 3 and 4 for now with 7mmx12mm fuel hose. Original is some kind of elbows, and they looks like fuel pressure lines with fabric inside. I did them with regular fuel hoses. Wait till weekend to change 8, that goes from connector to intake manifold. That's the one I asked in other post.
3. Also I changed one hose that hose from microfilter housing to intake manifold, it's 1/2'' or 13mm hose. It also has fabric inside as pressure hose but I changed with standard vacuum. I didn't find diagram for this one, just read about it here, cn90 wrote about that hose in his CCV replacement thread. See first pic in post where the highest "Cut this clamp" wording located.
Is there any other vacuum lines I need to replace?
Thanks!
Thanks!
