EDIT:
I'm curious WHERE the vacuum hose goes for the E39 CCV valves that do NOT have their CCV vacuum port plugged.
My theory (which is just a guess) is that this plugged port #9 on the back of my 2002 M54 engine is where the CCV vacuum hose 'would' have gone had it been in place.
- Engine => Vacuum control => AIR PUMP F VACUUM CONTROL
That plugged port is also shown as #17 in this diagram:
Engine => Intake manifold => Intake manifold system
Do you think this plugged port is what WOULD have been connected to the CCV if the CCV port wasn't also plugged?
NOTE: There is a typo in the caption; it should be "BTW, note the cracked condition of that endcap" (since replaced as explained here):
- How to locate all the vacuum hoses in the E39 engine bay
NOTE: We found the part number & size for the endcap over here:
- M54 vacuum hoses ... what diameter ... what brand ... what material ... what length?
NOTE: See also a thread which asks what the vacuum port on the CCV actually does:
- CCV vacuum hose important?
- On the M54 CCV, the vacuum port is closed off with an endcap
- On the M52, the vacuum port of the CCV provides vacuum for the fuel pressure regulator
- On the M62, the vacuum port of the CCV provides vacuum for the sucking jet pump
