Spark Plug DIY for E39 98 528
I did my sparkplugs today and boy am I sure glad I did them.
First off this is for a 98 528. Might be useful to someone. First what I did was I got the sparkplugs at AutoZone. I went with what my owner's manual said. My car had 4 prong NKG in there and my new plugs are 2 prong BOSCH. I like BOSCH better so that's why they went in there.
Proper Steps
1. Get New Plugs. Either NGK or BOSCH: 2 or 4 Prong.
2. Have some basic tools ready. A sparkplug socket is a must to make life easy.
3. Open driver side door and pull the hood release latch under the steering wheel.
4. Use a flat head screw driver to pry out the covers to get to the bolts so you can take off the engine cover. This is where a 10mm comes in handy.
5. Remove engine cover and oil cap and place to the side.
6. Unclip part next to sparkplugs and unbolt the 12 bolts that hold the 6 sparkplugs in place. Two for each sparkplug.
7. Replace old ones with new ones but make sure to put anti-seize on each new plug and then insert them back in place
8. Double check plugs are torqued at 21 lb/ft.
9. Place all bolts back in proper places and put the engine cover back on and bolt it in place and you're done.
First thing
Second
Part 3
Step 4
Step 5
Step 6
OLD VS. NEW
Old sparkplugs
Proper Steps
First thing
Second
Part 3
Step 4
Step 5
Step 6
OLD VS. NEW
Old sparkplugs
