DIY: 1998 528i Fuel Filter, Fuel Hose Replacement
33K views 14 replies 9 participants last post by  mnorton3256
#1 · (Edited)
There are a few excellent DIYs already, I just want to add my version.
NOTE:
* 1996-1998: simple fuel filter ---> cheaper at $18.
* 1999-2003: Fuel Filter has built-in pressure regulator ---> more expensive ($55 or so).
Excellent DIYs:
A mix of 1997 528i and 2001 530:
http://www.bimmerfest.com/forums/showthread.php?t=630970
Photo of Fuel Filter at 120k (Plus extensive DIY with photos)
http://forums.bimmerforums.com/forum/showthread.php?t=1809118
PARTS/TOOLS:
1. Parts bought from rmeuropean dot com (you can use EACEuro as well).
- MANN Fuel Filter
- Cohline Hose 2134.0600 has I.D. =7.5mm.
The factory is 8mm, but many people have used this 7.5mm hose without any issues.
Plus it is much cheaper to use this hose: $6/meter. I bought 2 meters just in case.
Car is 14 years old, I elected to change the fuel hose so I don't have to come back and take care of this later.
- Clamps x12
2. Tools:
- 8-mm, 10-mm socket
- Screwdrivers
- Wire cutter (to remove the Oetiker clamps)
- Right-angle pliers is a must, this tool makes removal of the fuel hose a breeze!
- Long-Nose Vise grip is very useful to remove worn out clamps (because the screwdriver can slip off the "break-away" clamps).
- Allen key for the Fuel Filter Clamp (5mm).
- Goggles to protect your eyes!
PROCEDURE:
1. Both LEFT tires on wood ramps.
- Remove the plastic shield (8-mm, 10-mm and plastic fasteners).
- For the plastic fasteners, pry the center tip out first, then the larger part later.
- Keep all these in a container to avoid loss!
2. De-pressurize the fuel system.
3. Look at the anatomy, I did not know how to change #7 (it is hooked to a plastic line so I assume it is the return and low-pressure line), so I left #7 alone. It looked good anyway.
- I also left the vacuum hose alone because it looked good.
- I replaced hoses labeled #1, #2, #3, #4, #5, #,6.
4. This photo shows the Right-angle pliers at work, twisting the fuel hose off.
- Don't pull the fuel hose, twist it first (use your other hand to stabilizer the other connection while twisting), then slowly work it out.
- For new hose installation, a bit of engine oil on the connector side makes a huge difference, it slides in very well.
5. When disconnecting some lines, some remaining fuel will flow out, so use the caps that came with the filter to temporarily cap the line.
- The Fuel Filter contains some gasoline, don't waste it, pout it into the lawn mower or the gas tank (with the forward arrow sign!).
- The Fuel Filter has an arrow, pay attention to this!
6. When all done, do not install the plastic shield yet.
- You need to check for leaks.
- Put key in ignition, turn to position II (do NOT crank engine!). Now remove key from ignition.
- Repeat this step about 10 times, this will prime the fuel system.
- Then start the engine and check for leaks.
- Re-install the plastic shield.
Final Product:
#4 ·
Jason,
The fuel hose did not look too bad, but at $6/meter, I elected to change them out at 14 years.
In this location, the Fuel Hoses were not exposed to engine heat.
Therefore they should last a long time, they don't crack from engine heat, but they harden with age (all rubbers harden with time).
#9 · (Edited)
Gotta add a pointer to this thread in the bestlinks so others find it first.
For the record, here's what is there before I do that:
- How does the E39 fuel injection work (1) & what are the most often recommended fuel pump & fuel filter brands (1) (2) & a DIY for replacing the fuel filter (0) (1) (2) (3) (4) (5) (6) & a quick test for fuel pump operation (1) (2) and a DIY for replacing the fuel pump (1) (2) (3) (4) (5) & how to replace and service your BMW E39 fuel injectors (1) & details on replacing the 7.52X3.52mm and 9.2X2.8mm fuel injector o-rings (1) & the location of the K96 fuel pump relay (1) & where is the fuel system pressure test Schrader valve for the I6 (1) & where is the fuel pressure test point for the V8 (1) (2) (3) & where is the location of the fuel pump relay K96 (1) & cleaning (1) (2) & replacing the fuel sensor (1) & resolving blown fuses due to a stuck fuel filler door solenoid (1)
I started looking, just out of curiosity, at how many fuel lines there are (whether they're hoses or tubes, or pipes, I don't know yet).
Starting just with the fuel filter diagram, is this the recommended set of hoses, clamps, and o-rings to consider replacing?
QUESTION: What does "L12-15" mean for a hose clamp?
#11 · (Edited)
The vacuum hose is the one that runs into the nipple on the Fuel pressure regulator which is shoved up into the 3/2 valve. Including a copy of the picture in your post would have helped a lot.
The yellow circle is the FPR. the yellow arrow shows the hose coming into it.
#12 · (Edited)
Update nine (9) years and 60K miles later...
  • I did this job in 2012 at 127K miles.
  • Nine (9) years and 60K miles later, the Cohline fuel hose leaked causing hard start when cold.
It'd drip a few mL on the driveway. The Cohline fuel hose leaked exactly where it was bent (please see photo). The Cohline hose with straight portion routing did not leak.
- Anyway, after some research, it appears that people reported on this issue in the Benz forum!!!
- Went to Advance Auto (who bought Carquest) and bought Gates 27340, this is a
fuel hose called Gates "Barricade"; rated for 225 psi. Hopefully this will last > 10 years.
Advance Auto sells this for $0.39/inch (yes, price per inch and not per foot). So much
for Cohline, made-in-Germany quality! Apparently, Gates fuel hose has good reviews.
- IMPORTANT TIP when working in cooler weather such as 5-10 deg C etc., the fuel hose gets very stiff, making insertion difficult!
In a perfect world, you do this job in July-Aug when it is hot bc the fuel hose is more pliable under the sun. In colder weather, use heat lamp or hair dryer and heat it up a bit (Gates website stated the spec's: - 40°C to 125°). So it you heat it to 60-80 deg C, no big deal. Also use a pen or appropriate socket to enlarge the ends first. Then after some moderate heat, it is soft and pliable, add a drop of oil on the male nipple part and the hose will slide in w/o issue.
- Photo showing cracked hose and new Gates hose and its design. Typical pen has an O.D. of 8-mm, it fits the I.D. of the fuel hose...
#14 ·
thats one way..or if you have a fuel pressure tester connect it to the schrader valve with a good sized rag handy and release the adapter a bit til it leaks and soak it up with the rag...or another is to have a good sized rag handy, carefully depress the stem on the schrader valve and catch the gas. all of the above on a cold engine of course.
